image sequence
COW Forums : Particle Illusion
mannyr
image sequence
on Jun 2, 2007 at 7:14:33 am
I need some help importing an image sequence as a background.
I have a folder with about 4 seconds' worth of png images sequentially numbered (a dance animation).
It's not rendered into a single file such as an AVI. I'll try that next but I thought PI could import the set.
When I double click on the layers' window gray square and get the background dialog box, I can only select single files but not the whole set of png's. What am I doing wrong?
Manny
Elvis Deane
Re: image sequence
on Jun 2, 2007 at 2:49:07 pm
Just select the first image in the sequence and open it. A dialogue box will pop up that asks you if you want to use that frame, or the entire sequence.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
MannyR
Re: image sequence
on Jun 2, 2007 at 4:46:02 pm
How did I miss that!!!
Works like a charm.
Thanks very much.
Manny
