rendering at 1920 x 1080
COW Forums : Particle Illusion
on May 31, 2007 at 11:00:46 pm
I am trying to render at 1920 x 1080. I know that the screen size is relative to the render size. Problem is my monitor is not that big and the max resolution for it is 1600 x 1200. Is there a work-around or other way to render that doesn't involve buying a larger monitor. Thanks.
Elvis Deane
Re: rendering at 1920 x 1080
on Jun 1, 2007 at 5:43:36 am
You can open your project file in pIllusionRender, the stand alone rendering application, and render it out to full size. It's in the same folder as the particleIllusion program, just run it, load the file, and go through the render options the way you would within pI.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
© 2018 All Rights Reserved
