PI 3.0.1 won't start
COW Forums : particle Illusion
Toddles
on May 30, 2007 at 2:46:04 am
When I run Particle Illusion it doesn't load up. If I then try to run it again I recieve a message that states "File damaged! (is there another copy running already?)". Any help would be much appreciated.
Cheers
Tod
Shaun
Re: PI 3.0.1 won't start
on May 30, 2007 at 10:10:31 am
I think I had this problem once or twice before. If I remember rightly, I ran the "reset default settings" program and it solved the issue - I think.
Shaun
Elvis Deane
on May 30, 2007 at 4:51:25 pm
Yup Shaun, you're absolutely right. If it ever doesn't run, go for that option.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
