Repeatable Crash in 3.04 and 3.05 with Intel Macs. When frame rate set to 0
COW Forums : Particle Illusion
BeenThere2
on May 17, 2007 at 10:25:01 pm
We've found a problem that repeatably crashes Particle Illusion. This has been tried this on different 3 Intel Macs. When in Emitter Properties, if you set the frame rate (in the bottom right of the window) to "0", then PI crashes. It just quits.
Also after the quit, when you reopen PI, the last file that was worked on, does not necessarily appear in the "Open Recent" in the FILE menu, even if it was saved before the crash.
Alan Lorence
Re: Repeatable Crash in 3.04 and 3.05 with Intel Macs. When frame rate set to 0
on May 17, 2007 at 11:10:21 pm
[BeenThere2] "if you set the frame rate (in the bottom right of the window) to "0", then PI crashes. It just quits"
Yes, I found that out while demoing at NAB. Just don't do that. =)
[BeenThere2] "Also after the quit, when you reopen PI, the last file that was worked on, does not necessarily appear in the "Open Recent" in the FILE menu, even if it was saved before the crash."
That's probably because the recent files info hasn't been written yet, but I have to check into that. It's probably written to disk at app close only.
Alan.
http://www.wondertouch.com
