Hellllllllllllp =( Asap! I Need to know how to Camera move ZOOM
COW Forums : Particle Illusion
chaucer44
on May 15, 2007 at 5:48:58 pm
Hi guys. Thanks in advance for helping!
1.) How do you control a background? I need to be able to FADE a background
> image in. The only controls I found so far only allow you to turn
> it ON and OFF; but I need to be able to fade it and have control over it's
> transparency, position etc..
> 2.) How do you create a ZOOM on your effect. I created a title with
> burning letters and I need it to slowly track towards the camera and pass
> completely past. I can fake it in adobe premiere with their zoom feature
> but it will pixelate badly. How can I achieve this camera move directly
> in Particle Illusion? The offset key allows up/down/sideways movement but
> there is absolutely no indication on how to ZOOM in on your finished
> object.
Essentially, in adobe photoshop terms, I'm looking for a way to FLATTEN all the layers into one effect and then do a controlled zoom in on it while keeping everything high res.
Thanks again!
My email account is impervium@aol.com Email if you can
Cris
p.s. these two questions relate to this logo video:
http://www.goldenarmor.com/cogfx1.html
I need to fade the background template in slowly (it's a still) and I need the cog logo to slowly zoom closer and we pass entirely through the center hole.
> Thanks in advance!!!
> Cris
Elvis Deane
Re: Hellllllllllllp =( Asap! I Need to know how to Camera move ZOOM
on May 15, 2007 at 8:27:44 pm
1) You can use some of the "Brightness Effects" emitters from the May 2001 library to do fades. You may have to do some fiddling with the timing Visibility graph, but the effects are there. As for panning and moving a background, there's just no way to do it in pI, unless you bring the image in as a particle shape and use it as a single particle emitter.
2) Animating the Zoom graph will increase the size of the entire emitter. It it's an area emitter or circle/ellipse, you'll have to animate the width-height or radius graphs as well. That will zoom the particles, but it won't zoom your background. You'd have to do that in an editing or compositing program.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
chaucer44
on May 15, 2007 at 8:39:09 pm
Thanks Elvis!!!!!!
Ahh figures I would find (just after 1 day of playing around) one of the only things PI doesn't do. Maybe on the next upgrade they can put the same kind of controls on b/g that they do for emitters.
Next question then, how do I create a custom made emitter of that logo shape. I basically need it as a template to be able to trace the fire patterns, then I need to drop it down to nearly invisible. GREAT idea about making it as an emitter and not a b/g. I basically just need the shape of it with an orange glow (non-moving) around it.
