Output PI effects with transparent background
COW Forums : Particle Illusion
dukesxm
on May 12, 2007 at 9:25:12 am
How does one output a PI effect with a tranparency background to be used as an overlay in FCP?
Elvis Deane
Re: Output PI effects with transparent background
on May 12, 2007 at 5:05:31 pm
When rendering to an image sequence or uncompressed Quicktime, just make sure to check the Save Alpha box in the Output Options window. A lot of the options are explained in this tutorial, which is for After Effects but should still help you understand the various options.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
dukesxm
on May 12, 2007 at 7:58:25 pm
Thanks a lot Elvis...I will give it a try
