export error: "invalid clipboard format - incorrect data (line 9, near column 0)
COW Forums : Particle Illusion
Graham Wellington
on May 11, 2007 at 10:30:38 pm
"After Effects error: invalid clipboard format - incorrect data (line 9, near column 0)."
My emitter's position refuses to be exported to AE 7.01 pro. I always get that error.
I tried with and without the offset check, neither way works.
I'm using the latest ParticleIllusion demo. I was hoping to buy this program to use in place of AE's motion tracker on difficult videos.
Elvis Deane
Re: export error: "invalid clipboard format - incorrect data (line 9, near column 0)
on May 12, 2007 at 4:53:42 am
The postion info in AE7 was changed slightly to require a bit of a workaround to move data back and forth between the two programs. This tutorial explains what you need to do.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Graham Wellington
on May 12, 2007 at 12:09:40 pm
I removed "position" in notepad and now there is no error but when pasting into AE7 it only adds one keyframe at the beginning.
Alan Lorence
on May 12, 2007 at 12:32:11 pm
When going from pI3 to AE 7, I think you need to add a single word.
Do this to compare clipboard data produced by AE 7 and pI3:
- Copy some AE 7 data to the clipboard, and paste it into Notepad.
- Export position data from pI3 to the clipboard, and paste it into Notepad.
- Check the differences, and edit the pI3 data so it looks like the AE 7 data.
Alan.
http://www.wondertouch.com
