help needed ASAP
COW Forums : Particle Illusion
MisticLass
help needed ASAP
on May 8, 2007 at 12:21:15 pm
hi
Im hoping someone can help me, I'm trying to make loopable backgrounds using Particle illusion.. I want to make as many as I can but unsure how to go about making them loopable.
The first partical im trying to make into a loop is one called...emitters_05_04 Twisted Tower ....if anyone knows how to make this one loopable as well as some of the others maybe has a tutorial that would work with this one an any of the others it would be of great help
Thank you
Jane
MisticLass
Re: help needed ASAP
on May 8, 2007 at 4:13:42 pm
Just thought I would add.. Iv just managed to loop some of the emitters by following a tutorial I found, but still having problems with emitters that are pre loaded like the one im keen on looping called emitters_05_04 Twisted Tower this emitter has preloaded frames of over 200 when I take the pre load away I cant get it to loop as the full emitter effect or it has a jump in the finnished render, can anyone help with how to loop emitters that need the pre loaded frames to get the full effect.
Alan Lorence
on May 8, 2007 at 4:19:48 pm
Try setting preload to 0, then work with frame 200 as the starting frame.
Alan.
http://www.wondertouch.com
MisticLass
on May 8, 2007 at 5:11:25 pm
I will try that now thank you Alan
