COW Forums : Particle Illusion
on Apr 29, 2007 at 8:06:14 am
We're using PI for a very large project (50 ft wide projection/HD) and I am noticing some aliasing on fine lines. PI is so integral to this project, is there any way to reduce the aliasing without the particles being soft? can we render without Open GL... would that help? our comps are rendered @1920x576 pix.
thanks in advance.
Alan Lorence
Re: aliasing?
on Apr 29, 2007 at 1:28:40 pm
You can't render without OpenGL -- all of pIllusion's rendering is done via it.
Can you post an image, or part of an image that clearly shows the problem?
© 2018 All Rights Reserved
