divX or Xvid problem 2 isssssues
COW Forums : Particle Illusion
on Apr 28, 2007 at 2:00:51 am
# 1
i got this Divx and Xvid installed but as i said before it leaves
watermark(when rendering in AE or PI3 to AVi),the quality is great and the file size small,specially for flash
but when i want to encode it to flv it goes through as if it was
doing its
job but at the end everything is blank
i thought maybe you could give some guidance as how to get rid of the
waterMark and if there is any setting so i can encode with help of
encoder or any other program and (with acceptable file size for the
thanks a couple of million
Elvis Deane
Re: divX or Xvid problem 2 isssssues
on Apr 28, 2007 at 4:20:51 pm
divx will watermark, you have to buy the full package to avoid them. xvid shouldn't watermark, it being open-source.
Huffy UV or Uncompressed would be your best bet in terms of quality, but the file size will be huge. If you're converting it to FLV in the end though, that's probably a good path to take (going to xvid and then flv gives you twice the chance to get artifacts/distortions in your final image).
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
© 2018 All Rights Reserved
