PI malfunction
COW Forums : Particle Illusion
Paul Hansen
PI malfunction
on Apr 23, 2007 at 5:45:03 pm
For no reason I can detect, the quick load library function no longer works. Quick load library shows with the little right hand arrow pointing right but... no libraries.
Alan Lorence
Re: PI malfunction
on Apr 23, 2007 at 10:40:11 pm
Did your "Emitter Libraries" folder get renamed? Did all of the files in it get deleted?
Alan.
http://www.wondertouch.com
Paul Hansen
Re: PI malfunction
on Apr 25, 2007 at 1:36:46 am
I moved the library to a different drive but kept the name "Emitters Library". When I do, "Load Library..." The program has no problem finding all the libraries and I can load them from there but not from "Quick load library"
Alan Lorence
Re: PI malfunction
on Apr 25, 2007 at 12:02:23 pm
The Emitter Libraries folder must be in the same folder that the particleIllusion exe is.
Alan.
Paul Hansen
Re: PI malfunction
on Apr 25, 2007 at 6:24:09 pm
Thanks, Alan... I guess I will just use the "Load Library" function then... my C drive is pretty filled up!
