TGA file sequence into Vegas
COW Forums : Boris FX Particle Illusion
Digit0
on Apr 22, 2007 at 2:25:58 pm
I have outputted a sequence from PI to TGA files as per Elvis Deans suggestion. When I call them into Vegas I can't get them to display under a second for each picture.
What is the correct procedure to do this?
Craig
Elvis Deane
Re: TGA file sequence into Vegas
on Apr 23, 2007 at 5:32:02 am
Check the bottom section of this tutorial, marked "From particleIllusion to Vegas"
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Soniclight
on Apr 25, 2007 at 2:45:45 am
Do you check the bottom box in Vegas Media import to read the whole sequence? When unchecked, only one frame will play (the second you mentioned :) This also applies to PNG files.
Digit0
on Apr 25, 2007 at 6:21:24 am
Yes. I checkboxed "open still image sequence" then select the frames I need.
I'm sill playing around with the "Alpha" settings as I'm not sure the differences between them.
