HELP!! QUES ABOUT COM SPEC!!
COW Forums : Particle Illusion
EOPAC_TEAM
on Apr 10, 2007 at 4:02:21 pm
I'm using PI3. The problem is the preview while process and after the rendering process, the avi file not run smooth. What must I do? Upgrade the RAM? Or Upgrade the graphic card? What is the best spec? Huwaaa..... :(
ryndemers
Re: HELP!! QUES ABOUT COM SPEC!!
on Apr 10, 2007 at 9:13:51 pm
how much ram do you have
and is you video card external and what kind?
Elvis Deane
on Apr 11, 2007 at 1:25:40 am
What compression codec are you using when you save the AVI? By default, you're probably saving out to uncompressed, which is around a meg a frame for a 640x480 image size. XVID and DIVX are good ones to save out to for viewing purposes.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
