Layers
COW Forums : Particle Illusion
PlUgOuT
Layers
on Apr 5, 2007 at 7:28:44 am
Well, This is new but nothings impossible.I want an emitter which gets tranparency from layer 1 and gets color form layer 2.Is this possible?
Thanx.
Alan Lorence
Re: Layers
on Apr 5, 2007 at 12:39:11 pm
No, not directly. Here's what you can do though: using another app, combine your 2 layers of footage into 1 layer of footage, using the color channels from one and the alpha channel from another.
Then use this new single footage layer in particleIllusion, with "get color from layer" and "get transparency from layer" checked. You can turn off the bg footage when rendering.
I think that will work.
Alan.
http://www.wondertouch.com
PlUgOuT
Re: Layers
on Apr 5, 2007 at 1:44:53 pm
Thanks!!! That really worked out.
PlUgOuT
Re: Layers
on Apr 5, 2007 at 2:28:14 pm
well, it didn't work out well.I combined the two videos and i add transparency but plusion doesn't recognizes it.
Alan Lorence
Re: Layers
on Apr 5, 2007 at 2:33:38 pm
Did you save it as PNG or TGA? If you used a different format, I'd suggest one of those two.
Alan.
PlUgOuT
Re: Layers
on Apr 5, 2007 at 3:04:19 pm
Owww Thats why Elvis Deane saved his video like that.Thanks ill try that.
PlUgOuT
Re: Layers
on Apr 5, 2007 at 3:19:59 pm
Do we have to save it with only png format.Cant we save it with tiff or targa?Cuz' Adobe Premiere doesn't support png.OR maybe you can tell me a PNG Plug-in(if it exists) For Premiere.!?.
Alan Lorence
Re: Layers
on Apr 5, 2007 at 3:35:31 pm
I said "TGA or PNG" didn't I? ;-)
I don't usually use TIFF because there are too many different "flavors", and particleIllusion doesn't support all of them.
Alan.
