HDTV
COW Forums : Particle Illusion
lsddigital
HDTV
on Mar 12, 2007 at 4:18:59 pm
Hi!
Can I export any animation to HDTV size? 1280x720 px
Alan Lorence
Re: HDTV
on Mar 13, 2007 at 12:14:37 am
Yes with particleIllusion 3.0. You have to set your project up for that resolution at the start by setting the stage size to 1280 x 720. Then, you have to make sure that you make the stage window itself big enough to fit 1280 x 720 (since pIllusion needs a visible window to render into). If you can't get a stage window large enough, you'll have to work zoomed out, then do your final render using pIllusionRender.
Alan.
http://www.wondertouch.com
