reverse blockers ( PLEASE REPLY)
COW Forums : Particle Illusion
ryndemers
on Feb 22, 2007 at 4:15:09 pm
a blocker stops the particles from showing in that box(or whatever shape)...
So is there a way so that a blocker(or sonmthing) ONLY shows whats in the box(or shape) ? nothing else but that
if that does not exist I would want that to show up the the next update.
This would be useful for putting emmiters on TVs and out windows and such
Thank you
PLEASE REPLY
Elvis Deane
Re: reverse blockers ( PLEASE REPLY)
on Feb 22, 2007 at 5:56:46 pm
Look under Layers under Tutorial 4 in the Help file and check out Stencil. It doesn't reverse a blocker, but it allows you to use a background's alpha channel to place the particles in a certain of the screen and nowhere else.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Alan Lorence
on Feb 22, 2007 at 6:09:47 pm
Why don't you just use multiple blockers? 4 rectangular blockers can easily be placed so that a "hole" is left in the middle.
Alan.
http://www.wondertouch.com
ryndemers
on Feb 23, 2007 at 6:17:15 pm
the problem I found with multiple blockers was that if the camera moves just a little, then you have to move 4 blockers -vs- just one. and thats annoying
Digit0
on Feb 28, 2007 at 7:15:40 am
I think I have similar situation. I have "blocked" around a guy with his hands on his hips facing the camera. I am unable to unblock the areas under his arms.
Craig
