Particle Illusion 4...any news?
COW Forums : Particle Illusion
stassiss
on Feb 4, 2007 at 7:53:56 am
Hi! I'm new here and i work with particle illusion. I read somewhere in an article that there might be a particle illusion 4 in the not too distant future and it might be quite a change in capabilities to version 3. Does anyone have any info, news or even rumous about this?
lasvideo
Re: Particle Illusion 4...any news?
on Feb 4, 2007 at 5:41:12 pm
And while we are at it, anyone have any info, news or even rumous about the PI3 After Effects plug in???
ryndemers
on Feb 5, 2007 at 12:14:36 am
I'm still waiting for a new update...
Alan Lorence
on Feb 5, 2007 at 11:26:08 pm
Here's what's in progress, and the probably order of release:
- particleIllusion 3.0.5 for Mac (Universal Binary)
- New Pro Emitters
- particleIllusion 3.0.2 for Windows (with enhanced movie support)
- pIllusion AE
- particleIllusion 3.5
Alan.
wondertouch
ae4life
on Feb 6, 2007 at 3:02:27 pm
any timelines
Jeron Coolman
on Feb 6, 2007 at 4:31:05 pm
Is Particle Illusion AE a separate product from the stand-alone Particle Illusion?
Alan Lorence
on Feb 6, 2007 at 4:49:28 pm
Yes, pIllusion AE is the plug-in version for After Effects.
Alan.
http://www.wondertouch.com
Jeron Coolman
on Feb 14, 2007 at 8:36:25 pm
Alan, does that mean we current particle illusion customers will have to buy a separate product license for pIllusion AE or will it just be an upgrade? or can we trade-in/crossgrade?
If I had pillusion AE, I have no reason to use the pillusion I have now. It is far more convenient for me and my workflow to use the AE plug-in instead of the stand-alone.
Alan Lorence
on Feb 6, 2007 at 4:48:58 pm
Mac 3.0.5 should be Feb release. New Pro Emitters should be Feb too. Win 3.0.2 is hopefully March. The rest is TBD (to be determined).
Alan.
Kesskisspass
on Feb 7, 2007 at 11:33:11 pm
I'm a mac (intel) user, if I buy the new particleillusion (3.0.5) when it will be available, does the 3.5 upgrade will be free ?
Alan Lorence
on Feb 7, 2007 at 11:54:58 pm
No, the 3.5 upgrade will be a paid upgrade. It will have many, many new features. It is at least 6 months away though.
Our upgrades are not expensive -- the 3.5 upgrade will most likely be less than $100.
Alan.
lasvideo
on Feb 8, 2007 at 4:20:43 pm
It seems that the AE plugin is a very low priority.
Alan Lorence
on Feb 8, 2007 at 4:32:36 pm
It may seem like that, but it's technical issues that have prevented its release, not lack of priority.
Alan.
Jeff Bellune
on Feb 13, 2007 at 10:34:07 pm
Re: The AE plugin. If it's not giving too much away, or committing to too much in advance, is your plan to keep the pI3 UI as part of the parameter setup in AE? Or are you planning to overhaul the interface to make it more like AE?
For example, Color Finesse has a simplified, AE-looking interface for adjusting parameters, but CF also has its own UI that opens up on demand from inside AE.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Alan Lorence
on Feb 13, 2007 at 10:47:03 pm
It will fit the AE UI.
It's been our intent all along NOT to put the entire pIllusion interface into the plug-in, but provide access to the "most-used" upper-level parameters, at least in the first version of the plug-in.
So, you'll be able to adjust "zoom", "size", "velocity", etc. for each emitter, but not for each particle type. You also won't be able to adjust other particle-level settings like reference point, color gradient (and all of the other color options), etc.
The idea is to make the huge pI3 library accessible within AE, and not overwhelm users.
Alan.
Jeff Bellune
on Feb 14, 2007 at 3:22:56 am
Thanks for the info, Alan.
Best regards,
-Jeff
Richard Lyall
on Jan 15, 2009 at 4:23:21 am
Any news on PI 3.5? Maybe a new features list? Will there be 3D support?
Richard
Richard Lyall
http://craftycurate.blogs.com
