Image Quality of Imported AVI Files
COW Forums : Particle Illusion
FeelTheLove
on Jan 30, 2007 at 8:34:12 pm
I am evaluating both PI3 and Trapcode. So far I like PI3, but have some concerns about the quality of my imported DV footage after running it through the suggested RAD tools and DIVX. I am getting very low quality and therefore this presents a problem. Any suggestions? Thanks so much for your time and effort.
Alan Lorence
Re: Image Quality of Imported AVI Files
on Jan 30, 2007 at 8:42:08 pm
Convert it to a PNG sequence. Use the Huffy UV codec instead. If using DivX, set the data rate as high as possible (on my system, I have DivX 5.05, and have the data rate set to 8 Mbps).
Other option is to install a DV codec and skip the conversion process altogether.
Alan.
wondertouch
Jose Burgos
on Feb 1, 2007 at 2:02:03 am
Yeah I never convert and import as is becasue of the codec are installed on my system.
Take care,
Jose Burgos
http://www.burgos-family.com/3d
JS9Reno
on Feb 1, 2007 at 9:02:05 pm
>>Other option is to install a DV codec and skip the conversion process altogether.<<
I am new to using PI and right now I'm just evaluating the SE version. Would you mind elaborating on this procedure of installing a DV codec. If it's important to know, my editor is Vegas 7. Thanks much!
Joe
Jose Burgos
on Feb 2, 2007 at 5:30:44 pm
If you captured the DV video using Vegas and it is on the same system that you are using PI, then you already have the codec installed.
Take care,
Jose Burgos
