"Not a valid particleillusion project file"
COW Forums : Boris FX Particle Illusion
simond
on Jan 16, 2007 at 1:38:29 pm
I'm trying to open several tutorial project files but each time I do I get the "Not a valid particleillusion project file" message. I can see the thumbnail fine in the Open dialog box but it never seems to be able to access the file.
Any ideas anyone? Using a trial of v3
Alan Lorence
Re: "Not a valid particleillusion project file"
on Jan 16, 2007 at 3:59:33 pm
Make sure that if it's a project file (ipf or ip3) then you use the "File - Open" menu to open the project. If it's a library file (iel or il3) then r-click in the library window and "load library".
Alan.
wondertouch
simond
on Jan 16, 2007 at 4:08:01 pm
Hi, it's an .ip3 file, taken from this tutorial:
http://www.creativecow.net/articles/deane_elvis/disintegratePeople/index.ht...
File: http://www.creativecow.net/articles/deane_elvis/disintegratePeople/project....
Alan Lorence
on Jan 16, 2007 at 4:46:37 pm
You say you're using a pI3 demo -- what version does it display in the "about" box? It has to be 3.0.1a or better.
Alan.
wondertouch
simond
on Jan 17, 2007 at 12:58:50 am
Thanks Alan, yep it needed updating :)
