Particle Scale
COW Forums : Particle Illusion
Kevin Snyder
Particle Scale
on Jan 1, 2007 at 6:28:46 am
Is there a way to scale a particle over time in just the x direction? I want a line to get wider over time, but I don't want the height to change. Should I just animate a line in AE and then bring it into PI as a particle?
Thank you.
KMS
MrBill
Re: Particle Scale
on Jan 1, 2007 at 2:32:52 pm
Kevin,
Add the emitter to the stage then left click "size" choose "unlock aspect" you can then set the
Kevin Snyder
Re: Particle Scale
on Jan 2, 2007 at 4:58:05 am
Great! Thank you very much!
KMS
