S;pw Motion
COW Forums : Particle Illusion
russ930
S;pw Motion
on Dec 27, 2006 at 3:48:43 am
Can anyone tell me how to slow down the effect of a emitter? I am using the Space Explosion 2 effect and would
like to slow the explosion down.
Thanks in Advance
Tinger
Re: S;pw Motion
on Dec 29, 2006 at 8:51:37 am
Russell,
What sometimes works is to increase the amount of frames in the project. Then play it back at normal rate.
Craig
russ930
Re: S;pw Motion
on Dec 29, 2006 at 9:56:54 pm
Aharon Rabinowitz
Re: S;pw Motion
on Jan 3, 2007 at 10:37:22 pm
yes and no. if any of the properties are animated, the animation will need to be scaled - select the property ancd right click in the timeline for the option.
Also - if the partricle shape is made from a sequnce of images that are playing, this won't work because when you record at a higher frame rate it will cycle those images much faster. The only solution I know if is to make your own image sequences that account for this - so make an image sequence with more frames.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
