particleIllusion 3.0 Emitter Library
COW Forums : Particle Illusion
russ930
on Dec 18, 2006 at 5:30:21 am
I have downloaded the emitter library but can not open them in Particleilluison.
Can anyone help me out?
Alan Lorence
Re: particleIllusion 3.0 Emitter Library
on Dec 18, 2006 at 12:35:10 pm
If you put them in the "Emitter Libraries" folder then use the "quick load" library list (r-click in the library window) to load another library. You can also use "load library", or click the bar that is between the library window and the preview window.
Alan.
wondertouch
russ930
on Dec 18, 2006 at 9:21:47 pm
Thanks, that worked, but can you tell me where the orginal
Library went?
russ930
on Dec 18, 2006 at 9:23:34 pm
I figured it out. Is it not possible to have all of the librarys loaded and visable at the same time?
Alan Lorence
on Dec 18, 2006 at 9:54:14 pm
No. You can use the Library Manager though.
Alan.
wondertouch
