Suggested updates for PI
COW Forums : Particle Illusion
Paul Hansen
on Dec 9, 2006 at 8:17:55 pm
In the emitters properties window, under color, use gradient normal: It would be great if the repeat slider could have an "n" value so it's speed could be altered over time, also with the transparency over life slider, and, on the slider when you have an emitter that uses several different images. it would be great to be able to alter that speed over time.
eye design
Re: Suggested updates for PI
on Dec 10, 2006 at 4:10:32 am
I agree
shadu
on Dec 12, 2006 at 6:43:49 pm
Other transfer mode could be very good also.
Shadu
Tinger
on Dec 29, 2006 at 9:04:51 am
Hi All,
What really would be nice is if when you are editing in the any graph window that the window display's the graphs actual position right away so we don't have to scroll up and down first.
Craig
