Warp Lines Out
COW Forums : Boris FX Particle Illusion
Mike
Warp Lines Out
by
on Dec 7, 2006 at 6:45:27 pm
How can I simply change the direction of the warp line son this emitter? Instead of flying out at me I want them to go from left to right. Is it possible?
Alan Lorence
Re: Warp Lines Out
on Dec 7, 2006 at 7:11:42 pm
There are several steps -- hope I get them all:
- r-click on the emitter on the stage and "make line"
- select "emission angle" in the hierarchy and set to 90
- select "emission range" and set to 0
- move the line points so the line is vertical
- move the emitter to the left edge of the screen
- open emitter properties dialog and uncheck "emit at points"
You may have to adjust "number", or "size"
Alan.
wondertouch
