nuclear explosion
COW Forums : Particle Illusion
giglu231
nuclear explosion
on Nov 16, 2006 at 3:36:51 pm
Hi! I am a new user.
I would like to obtain with P.Illusion a nuclear explosion.
does an emitter exist already?
Thanks in advance for every answer.
bye
Elvis Deane
Re: nuclear explosion
on Nov 16, 2006 at 7:19:53 pm
There are a whole bunch in the July 2004 library.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
giglu231
on Nov 16, 2006 at 8:30:00 pm
yes
I have seen it, even if
it is not very realistic.
I try to modify it.
can you tell me something about it?
Elvis Deane
on Nov 19, 2006 at 10:31:42 am
The motion of the emitters is really good in those, so if you replace the particle shape used in the smoke emitters with something that has more detail in it, you'll probably get an explosion closer to what you want.
A few things I did to adjust the 01b nuke:
Duplicated the Smoke Plumes particle type in the left and right free emitters. I then loaded up the August 2006 library, and used the waterflow_new6 shape on those new smokes. That added a bit more detail to the smoke.
I also reset the Tint Strength graph to give the explosion more intense colours.
Elvis Deane!
