How do I install emitters?
COW Forums : Particle Illusion
xAbre1200
on Nov 8, 2006 at 6:48:31 am
I am quite confused. I just downloaded the emitter libary for SE and I have no idea what to do with it. I created a file in the particle illusion folder in the C: drive and coppied the emitter libary i downloaded into it, but nothing happens. Some help would be quite appreciated.
Cheers
Elvis Deane
Re: How do I install emitters?
on Nov 8, 2006 at 6:33:45 pm
You should place any library files in the Emitter Libraries folder where particleIllusion is installed. Then go into the library window, right-click and choose Load Library, and the new libraries should be available to load up.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
