Deflector
COW Forums : Particle Illusion
shadu
Deflector
on Nov 6, 2006 at 1:27:30 pm
I need to do a effect similar to this one: http://download.blender.org/demo/movies/particle_heat_ray.mov
Is it possible. I don't ask about the 3D movement, just the deflector effect in this small movie.
Shadu
Alan Lorence
Re: Deflector
on Nov 6, 2006 at 1:51:24 pm
Have you tried doing this yet? It is quite simple -- just use a deflector.
Here is an example file I quickly put together.
http://www.wondertouch.com/downloads/temp/cow/deflector_heat.zip
Alan.
wondertouch
shadu
Re: Deflector
on Nov 6, 2006 at 8:49:42 pm
I did try but without big succes. Nerver got the right. I think your weighless particule emitter did the trick. Before i tried it with partucle without weight and lot of speed...
Thanks... I will try that.
Shadu
shadu
Re: Deflector
on Nov 7, 2006 at 6:08:14 pm
Thanks again Alan. Never thinked about using the weight of the particle to do this effect... Good thinking.
Shadu
