Changing the speed of the entire effect?
COW Forums : Particle Illusion
Whitetail
on Oct 30, 2006 at 3:52:17 pm
I apologize for asking such a newbie question, but I have gone through a few tutorials and cannot find an answer. I would like a way to slow down the entire effect. I thought the velocity parameter would do this, but it does not. I am rendering it and bringing it into Premiere and slowing it down on the timeline as a workaround.
Bob Bonniol
Re: Changing the speed of the entire effect?
on Oct 30, 2006 at 10:11:55 pm
Sometimes an effect will have several components. For instance some of the snow effects I am currently working on have very small, small, medium, and large flakes, each with it's own velocity control. So in some cases you have to adjust things in multiple layers. Also, depending on the effect, what you might be terming the "speed" might have more to do with particle numbers, or birth rate, velocity over life, or velocity variation. Make sure to check out all that stuff.
Hope this helps.
Best,
Bob Bonniol
MODE Studios
http://www.modestudios.com
Contributing Editor, Entertainment Design Magazine
Art of the Edit Forum Leader
Live & Stage Event Forum Leader
HD Forum Leader
