Creating Sun Flares
COW Forums : Particle Illusion
djones
Creating Sun Flares
on Oct 17, 2006 at 6:50:35 pm
I am trying to create a corona effect to show sun flares.
The corona emitter that I downloaded rotates around the circle. I can't find how to stop the rotation. The setting for spin or rotate are at 0. Changing the angle has no effect, nor does emission angle or emission range.
I've tried using a fire line and converting it to a circle emmitter, but the flames travel upwards and not out away from the circle. When I change the rotation I totally lose the flame effect.
I've tried turning emit from inside / outside on and off to no avail.
Any suggestions???
Elvis Deane
Re: Creating Sun Flares
on Oct 17, 2006 at 10:51:07 pm
What's the exact name of the emitter? Spin and Spin Variation would have been my first suggestion, so it must be an emitter that has something done that's different than the norm.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
djones
on Oct 18, 2006 at 1:45:37 pm
Corona (feb_07)
Spin and Spin Variation are both at 0
djones
Re: Creating Sun Flares velocity
on Oct 18, 2006 at 3:02:00 pm
Turns out that the velocity was causing the flares to rotate around the circle.
Thanks for your help.
dj
