pI_Render fails to run
COW Forums : Boris FX Particle Illusion
metaphilos
on Oct 12, 2006 at 9:32:10 pm
Someone described a similar problem but he never responded back if he had found a solution.
I used pI_Render successfully for a long time and then did not use it for a few months and
when I tried to use it, it just closes.
My problem occurs when I open pI_Render and select AVI Options; the program closes. I have no problem with ParticleIllusion in rendering an avi.
Has anyone experienced this problem and is aware of a solution.
Thanks.
metaphilos
Re: pI_Render fails to run
on Oct 12, 2006 at 10:29:49 pm
I just wanted to add to the previous message that I am able to use pI_Render to create an
avi, if I do not select AVI Options. The avi that is created uses the Cinepak codec by
default.
Thanks.
Alan Lorence
on Oct 16, 2006 at 3:38:49 pm
There's a utility called "Sherlock - The Codec Detective" that you can download to see if any of your codecs are "broken":
http://www.free-codecs.com/download/Sherlock_The_Codec_Detective.htm
That might help.
Alan.
wondertouch
Alan Lorence
on Oct 14, 2006 at 12:25:29 pm
There seems to be some problem with pIRender in the AVI area. I just checked it myself (I don't use pIRender very often), and I get an error message about the "H263 codec maximum size is ___ x____, please choose another codec", but the AVI options still displays after that. Then, I notice that at least one of my codecs is not listed there.
I thought that maybe the project that was loaded had a weird stage size which wasn't compatible with some codecs, so I unchecked "autoload" and restarted pIRender so it loads with no settings, but it gave the same results.
The only thing I can suggest is to render an image sequence with pIRender, then use another app to make it into a movie (if needed).
Alan.
wondertouch
