Line emitter question
COW Forums : Boris FX Particle Illusion
MrBill
on Oct 1, 2006 at 11:12:25 am
Is there a way to move the pivot point of a line emitter?
I would like it to pivot on one end rather than from the center.
Thank you,
Bill
Alan Lorence
Re: Line emitter question
on Oct 1, 2006 at 12:25:34 pm
Just move the points that define the line.
Alan.
wondertouch
MrBill
on Oct 1, 2006 at 1:07:40 pm
Thank you Allen,
To get point 2 to revolve around point 1 I would start with point 2 at 0 degrees relevent to point 1 advance few frames set point 2 at 90 degrees to point 1 advance a few frame set point 2 at 180 degres to point one etc., till I get a 360 degree rotation?
Is this correct?
Thank you,
Bill
Elvis Deane
on Oct 1, 2006 at 4:43:13 pm
If you move point 1 over the reference point (the smaller point that appears between the two points when you create a line emitter), you can use the Angle graph to rotate point 2 around point 1.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
MrBill
on Oct 1, 2006 at 7:09:14 pm
[Elvis Deane] "If you move point 1 over the reference point (the smaller point that appears between the two points when you create a line emitter), you can use the Angle graph to rotate point 2 around point 1."
Thank you, Elves I will give that a try. :-)
Bill
MrBill
on Oct 1, 2006 at 7:31:01 pm
Oh yeah! Elves lives! :-)
Thank you it worked perfectly.
Bill
