creating a fresh emitter
COW Forums : Particle Illusion
on Sep 26, 2006 at 11:55:03 am
hi, i'm a noob to particle illusion 3. i've went through all of the tutorials that the help files in the program gives you. i have not seen any documentation on how to create a fresh emitter without using one from the library. i can not believe that there is not a blank emitter option. i am probably overlooking something. can someone please help. thank you.
Elvis Deane
Re: creating a fresh emitter
on Sep 26, 2006 at 7:15:07 pm
You can grab the blank library here off the wondertouch site.
You can also create a blank emitter by opening up a library's Properties window, selecting one of the folders, and clicking on the Add Emitter button at the bottom of the window. If you have an emitter selected rather than one of the folders, you'll get a duplicate of the selected emitter, so make sure you are on a folder to create a blank.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
© 2018 All Rights Reserved
