Water Jet Question
COW Forums : Particle Illusion
Paint Guy
Water Jet Question
on Sep 15, 2006 at 12:06:46 am
How do I vertically lengthen the "water jet" particle. My background image is a glass of water. I want to pour water out of the glass and right now the water (the water jet) starts halfway up the image and when it loops it jumps back up to it's starting point. How do I fix this? Will lengthening the "Water Jet" so it starts outside of the image area work? And if so how would I do this? Hope this makes sense.
Elvis Deane
Re: Water Jet Question
on Sep 15, 2006 at 9:09:52 pm
I'm not sure exactly what you're asking, but if you want the water to go further, you can increased the Velocity (it'll make the particles go faster, and therefore further). You can also decrease the Weight on that particular emitter to stop the stream from bending so much, or increase it if you want it to bend more.
