daVinci style pain stroke
COW Forums : Particle Illusion
Andres
on Sep 12, 2006 at 7:16:33 pm
I need to create a "davinci style" paint stroke which will be reveling an object. Do you PI experts think i should tackle this in Particle Illustion or should I look for a different solution?
Alan Lorence
Re: daVinci style pain stroke
on Sep 12, 2006 at 8:02:45 pm
I'm not sure what you mean by this. Can you give an example, or better explanation?
You can use some of the emitters to do a "brushstroke" type effect, but it may not be what you want.
Alan.
wondertouch
Andres
Re: daVinci style paint "brushstroke"
on Sep 12, 2006 at 8:37:22 pm
I dont have a specific example per say. What i had in mind is like u said a simple brushstroke which would reveal a high-rise building. I looked through all the emitters but found none. I'm I overlooking one? What Library do u recommend for "brushstrokes"?
thanks in advanced
Elvis Deane
on Sep 12, 2006 at 11:36:14 pm
Is this the sort of thing you mean? You have to manually animate the stroke thickness, which can be done in the Size graph.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Andres
on Sep 13, 2006 at 2:32:23 am
Thanks for the file. but not quite. Maybe its just my lack of knowledge of the program. What i had in mind was a more fluid brush stroke like this: almost like a quick sketch - see link
http://www.d-work.us/temp/brushstroke.jpg
