Replacing Emitters
COW Forums : Particle Illusion
Clifford L. Frazier
Replacing Emitters
on Sep 10, 2006 at 3:52:31 am
I tried following the tutorial for replacing emitters on the stage but it didn't work. The instructions state that a new emitter should be picked in the library. Then the stage emitter should be chosen by R-clicking on it. A box is supposed to appear showing replace as an option. I did all of that but while the window did appear, there was no option to replace. Import, Export, etc. yes, but not replace. Please advise how I can replace the emitters. Thanks
TechnoRev
MrBill
Re: Replacing Emitters
on Sep 10, 2006 at 4:31:22 am
Are you using Version 3 or SE?
Elvis Deane
on Sep 10, 2006 at 5:00:59 am
Make sure you're right-clicking on the emitter object in the Stage, not its name in the Hierarchy window. The Replace command is only available in the Stage's right-click menu.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
MrBill
on Sep 10, 2006 at 12:31:37 pm
Elvis,
Am I correct in thinking it is only a PI3 feature?
Bill
Elvis Deane
on Sep 10, 2006 at 6:05:21 pm
You are correct, it's only in 2 and 3, not in SE.
Elvis Deane!
Alan Lorence
on Sep 10, 2006 at 2:15:48 pm
The key is to r-click on the emitter in the stage window, not in the hierarchy where you r-clicked it.
Alan.
wondertouch
