How can this be done?
COW Forums : Particle Illusion
dotan
on Sep 9, 2006 at 5:00:39 pm
Can i create this effects like fire/water using PI3?
http://www.jcspost.co.il/download/animations_files/13406.wmv
thanx
Alan Lorence
Re: How can this be done?
on Sep 10, 2006 at 2:25:31 pm
Something similar, but not exact. The fire is the easy part, but the water may be impossible. The reason is, in that clip the water is "smooth", and you can see the person behind the water. pIllusion doesn't do "smooth" water very well, as that's a job for a fluid simulation/renderer, not a sprite-based particle system.
For the fire, you also won't get as much 3D to it, but you can do it by animating the "zoom" property.
Alan.
wondertouch
dotan
on Sep 10, 2006 at 3:37:53 pm
Thanx alan
so what did they use to do that?
3D application?
bjohnston
on Sep 20, 2006 at 12:41:06 am
Probably REALFLOW.
