Chroma Key Values
COW Forums : Particle Illusion
MrBill
Chroma Key Values
on Sep 8, 2006 at 3:35:37 pm
When working in PI I can import my video and have at it, but when I need to send off that video effect without the finished background (Just the effects Ma
Elvis Deane
Re: Chroma Key Values
on Sep 9, 2006 at 2:17:30 pm
Just curious why the black background wouldn't be best in some cases. Saving out the effects against a black background with an alpha channel makes it pretty easy to re-composite in other programs, especially when you check the Remove Black BG box in the Render options.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
MrBill
on Sep 9, 2006 at 3:26:56 pm
[Elvis Deane] "Saving out the effects against a black background with an alpha channel makes it pretty easy to re-composite in other programs, especially when you check the Remove Black BG box in the Render options."
This identifies my problem I do not know and can not find the afore mentioned "Render Options."
I just rendered a test and did not see that option, I also looked in the Preferences and Project Settings.
Where do I find it?
Thank you,
Bill
MrBill
on Sep 9, 2006 at 3:51:15 pm
I see why I am rendering to AVI and I need to render to an image say png format to use those options.
I went back and rewatched some of your DVD. ;-)
Bill
