Lightning 2 The Return :-)
COW Forums : Particle Illusion
MrBill
on Sep 2, 2006 at 7:36:02 pm
If you liked Lightning you'll love The sequel, Lightning 2. :-)
Different URL same great content. :-) (I am in the process of switching over domains.)
http://latentimageproductions.net/pi/lightning2.zip
I used the 512x512 textures again I had already started them so I used them.
I did try to resample them in PI, it did not work out at all.
Next one I will give it a go with a smaller texture size.
As always comments welcome.
Bill
Cinematographers bring Shadow to Light
MrBill
Lightning 2b it just gets better and better :-)
on Sep 3, 2006 at 10:47:48 pm
I went in frame by frame and adjusted the bolts so there are no dead ends in mid strike.
I think it looks cleaner than version 2 that
Crunker
Re: Lightning 2 The Return :-)
on Sep 12, 2006 at 9:16:06 pm
Is there a way that I can change this emitter in order to make it look like the electrical discharge is heading from one location to another?
MrBill
on Sep 16, 2006 at 2:26:42 pm
You could export the shape, rotate each image to the proper angle and create a new shape or you can change the angle of the Layer so the bolts shoot horizontal rather than vertical.
Then position and size the emitter as needed.
Bill
Crunker
on Sep 16, 2006 at 9:40:11 pm
I don't really follow....
Can someone just teach me how to make an emitter? From scratch?
