loading a sequence
COW Forums : Particle Illusion
joeyboy
loading a sequence
on Aug 31, 2006 at 2:14:21 am
hi,
i'm loading an animation sequence that i rendered in maya to use as an alpha emitter. the problem is it doesn't load all of the frames. i rendered 100 frames but the program says "the sequence has 9 frames...".
thanks,
joeyboy
Elvis Deane
Re: loading a sequence
on Aug 31, 2006 at 7:28:15 am
It's probably due to the way the sequence is numbered. There should be some frame padding options within Maya's render settings. Make sure that the render comes out like:
file_0001, file_0002, file_0003, etc.
and not
file_1, file_2, file_3 to file_11, etc.
You can grab a free renaming program (I have one named Lupas Rename 2000 that works pretty good) if that is what the problem is. It usually beats renaming the files manually or rerendering.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
joeyboy
on Aug 31, 2006 at 11:40:19 am
thanks a lot!
maya can't seem to render with that naming system so i had to rename the rendered files. problem solved, thank you sir. i'll try to look for the program that you mentioned. it will be very useful.
Elvis Deane
on Aug 31, 2006 at 4:54:38 pm
If you look in the Maya Render Settings, under the Image File Output section there should be a Frame Padding box. Change that to 3 or 4 to give yourself some extra zeros.
Elvis Deane!
joeyboy
on Sep 1, 2006 at 12:52:10 pm
thank you sir, i guess i need to dig more into the render settings.
thanks again!
