Elvis Deane's disinteegrating persons-tutorial...doesn't work :(
COW Forums : Particle Illusion
chrissibollen
on Aug 23, 2006 at 8:17:59 am
I was trying to do Elvis' tutorial (disintegrating persons),downloaded the package.zip file and wanted to do it like it is explained on the website.
But somehow it seems as if the "Get color/transarencsy from layer" would not work, the emitter is still shown on the entire of the video :(
What can I do??
thanks,
Chrissi
Alan Lorence
Re: Elvis Deane's disinteegrating persons-tutorial...doesn't work :(
on Aug 23, 2006 at 3:42:03 pm
Make sure you understand the tutorial. It does work. Read it over again.
Alan.
wondertouch
Elvis Deane
on Aug 24, 2006 at 8:03:49 pm
If it's shown over the entire video, then it means either you have the emitter on the wrong layer and it isn't taking into account the transparency information from the background image, or your background image doesn't have an alpha channel.
If you're using the footage in the zip, then it should work fine.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
