Rotating emitters just a bit
COW Forums : Boris FX Particle Illusion
evideom
on Aug 18, 2006 at 10:43:04 pm
How can I do this? I assume there is no way to do it in PI. I was wondering what I need to do to get the black back round to be totally transparent so I can maybe rotate it a bit in AE.
MrBill
Re: Rotating emitters just a bit
on Aug 19, 2006 at 11:21:52 pm
Open the propeties dialog.(For the emitter you wish to adjust.)
Click on the Particles tab. (Top)
Click on the Behavior tab. (Just below the partical preview window)
Select Specify under Partical Angle. (an option setting opens just to the right)
Use it to change the angle of the emitter.
Bill
