pI Output size doesn't increase in ratio - cannot get above 520x480
COW Forums : particle Illusion
RiW SFX
on Aug 11, 2006 at 2:23:05 pm
I have made a short project in Particle Illusion, but when I come to export I cannot maintain the correct ratio. I want 100% zoom - i.e. full 640x480 quality, but when I enter 100% the ratios I get given are 520x480 and I cannot change them. In fact, increasing the zoom level over ##% only increases the height, leaving the width contstantly at 520.
how can I solve this please as my project is designed for 640x480
Alan Lorence
Re: pI Output size doesn't increase in ratio - cannot get above 520x480
on Aug 11, 2006 at 3:57:52 pm
Make your stage window large enough to fit a 640x480 stage at 100% zoom.
Alan.
wondertouch
RiW SFX
on Aug 11, 2006 at 8:27:44 pm
How do I do that please?
I have right clicked and done Zoom to fit, but still on 100% zoom when I sleect output the max I get is 520x240, but I can get the right ration if I sleect a smaller zoom (e.g. 10% = 64x48) I have also tried zooming further out and then clicking the output button, but still making no progress
Thanks for any ideas to fix this
Alan Lorence
on Aug 11, 2006 at 9:20:36 pm
You didn't read what I wrote.
Make the stage window larger. Drag the edges, or use Alt-3 to zoom the stage.
You can also use pIllusionRender.
Alan.
wondertouch
RiW SFX
on Aug 12, 2006 at 9:41:13 am
Thanks, sorry I didn't understand your first response.
The Alt-3 worked fine, then I can get back to my normal view with Alt-1
