There is some lib to do this?
COW Forums : Particle Illusion
Khrysller
on Aug 10, 2006 at 1:37:25 pm
@ 00:09 to 00:11 seconds in http://awm-media.tm73.com/AWM%20Demo%20Rough1Mbps_Stream.wmv ...that white line rounding the place..
posted here:
http://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=173&postid=...
Alan Lorence
Re: There is some lib to do this?
on Aug 10, 2006 at 5:37:57 pm
You can get something similar using a "trail" emitter, but it won't be exact. You can make one of these emitters by setting velocity to 0, increase number to a pretty high value, then draw the emitter path. Probably looks best if you use a shape image that slightly long and thin, and angle it at 45 degrees or so. You may want to use the size over life graph too.
Alan.
wondertouch
Khrysller
on Aug 11, 2006 at 5:08:05 pm
@ Alan, thanks for reply... gonna test it ^^
@Elvis, I tried yours... it
Alan Lorence
on Aug 11, 2006 at 5:10:11 pm
It's not an effect that you can do easily with particles. You're trying to make a very smooth line with many small dots. Not the best way.
Alan.
wondertouch
Khrysller
on Aug 11, 2006 at 5:19:19 pm
This is good in some point...
what is missing to make PI possible to do this in a easy form?
maybe this 'thing' could allow ways to do a LOT of other kinda of effects in PI.. of course without leaving the PI focus.
it
Elvis Deane
on Aug 10, 2006 at 7:09:02 pm
I made some attempts at a similar effect a looong time ago (the request that time was for streaks like the ones Trapcode's 3D Stroke makes). I never got it quite right, but you can check out the project file here. By adding some high quality motion blur, it may end up looking pretty good.
You can grab it here
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Tony Mueller
on Aug 18, 2006 at 9:32:20 pm
Hi there,
I'm the guy who's guilty of posting that demo reel... I made those strokes based on this tutorial:
http://www.creativecow.net/articles/velez_dean/glowing_stroke/index.html
Khrysller
on Aug 18, 2006 at 10:18:19 pm
WOW nice... gonna follow this and try after...
thanks for reply dude...
i really enjoy what u have done : )
