falling away
COW Forums : Particle Illusion
Mike
falling away
by
on Jul 19, 2006 at 2:38:25 pm
Is there a way to make particles fall back from the screen as if being sucked down a black hole?
enigma735
Re: falling away
on Jul 19, 2006 at 4:02:04 pm
If you want it to be sucked "straight" back....you could just change the size over life. Start at whatever your desired beginning height is.. and then over a period of 10 or so frames (less frames if you want it faster, more if you want it to be sucked in slower) add keyframes that are descending on the Size over Life graph. That should give it the "sucked in / disappearing into the background / riding off in the distance" feel. If you're trying to do something with a ghosting effect, it may be a little tougher to do, i'm still learning this wonderful program so perhaps one of the great guys that are very experienced with pI could help you with that.
