Resolution
COW Forums : Boris FX Particle Illusion
Montekristo
Resolution
on Jul 8, 2006 at 12:17:27 pm
Hi there!
How can I make PI's stage 720x480 since when I hit Alt+3 it becomes too large.
And when I render AVI for further processing in Premiere Pro 2.0 it is smaller than the 720x480. What am I doing wrong?
Thanks.
Best regards
Montekristo
Elvis Deane
Re: Resolution
on Jul 8, 2006 at 5:54:14 pm
What do you mean that it becomes too large? What is your monitor's resolution set to?
Instead of hitting Alt+3, you can always just grab the borders of the Stage window and drag them out to make them larger. Just so long as the stage area is bigger than 720x480 when you hit the render button, you should be fine.
Montekristo
Re: Resolution
on Jul 11, 2006 at 6:27:29 am
Well,
I've finally got it!!! Thank's Elvis!!!
