Error code 00000005
COW Forums : Boris FX Particle Illusion
newbie0221
Error code 00000005
on Jul 7, 2006 at 5:34:49 pm
I have just installed Particle Illusion 3.0.1 and have been receiving a message "Error Code: 00000005" that prevents the program from even starting up. Has anyone encountered this problem and if so, what did you do to correct this. I appreciate all help in advance, thank you.
Alan Lorence
Re: Error code 00000005
on Jul 7, 2006 at 5:47:02 pm
Probably means you don't have a C: drive. Email wondertouch support for more help.
Alan.
wondertouch
superal
on Sep 13, 2006 at 9:44:25 am
Same problem, and I definately have a C: drive!
Was there a solution for this?
Alan Lorence
on Sep 13, 2006 at 12:36:39 pm
In order to allow non-administrator users to run particleIllusion 3 on
Windows XP, log in using an Administrator account, then run the attached bat
file. This should modify the license file to allow all users to access it.
Just unzip it, and double-click it.
http://www.wondertouch.com/downloads/pi3_user_access.zip
Alan.
wondertouch
Derek Davis
on Jul 25, 2008 at 12:11:33 am
Hi there. I am having the same problem and tried the patch but it's still not working. "Error code 00000005" still pops up and the program won't start. Please help!
