[resolution]
COW Forums : Particle Illusion
digisummo
[resolution]
on Jul 2, 2006 at 7:54:33 am
Hello Everyone,
I am creating lower thrids and transitions for a television broadcast but when I render my .tga files at 720x480 with no compression with Alpha and import them into After Effects they are smaller than the 720x480 setting in After Effects. What am I doing wrong?
Elvis Deane
Re: [resolution]
on Jul 3, 2006 at 7:06:04 am
Is your stage larger than 720x480, and is it set to 100% zoom? That's the main reason people have renders that don't match their project size. If not, drag the sides of the window to make it larger, or hit Alt+3 to maximize it before you render.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
digisummo
Re: [resolution]
on Jul 4, 2006 at 4:41:20 am
Thanks Elvis,
you rock.
