Sabrina the teenage witch effect
COW Forums : Particle Illusion
Magicmatty
on Jun 30, 2006 at 4:34:53 am
Hi, just wondering if anyone knew how to do the magic effect in sabrina the teenage witch tv show. Here is a video of it (its at the end of the video)
I have an emitter like it but when she does it covers all of britneys body really fast. I was trying to record the postions but its too slow and when i do it frame by frame its not smooth.
Thanx
Matthew
Magicmatty
Re: Sabrina the teenage witch effect
on Jun 30, 2006 at 5:31:23 am
heres another video, you can see that there is a glow to it and her clothes sceem to get light too.
Matthew
Alan Lorence
on Jun 30, 2006 at 5:32:16 pm
I think you should manually keyframe this, and use "curved" position keys. If you want it to do an "S" shape, create some position keys a few frames apart, then r-click on each point in the stage and make it "curved". Then adjust so the emitter follows the path you want.
The key is not creating a position key at every frame.
Alan.
wondertouch
magicmatty
on Jul 1, 2006 at 1:11:29 am
Hi, The emitter it cutting the edges and its not smooth is their a tutorial on this?
Thanx
Cenk Yartan
on Apr 19, 2008 at 3:03:05 pm
Yeah i had exactly the same problem. The emitter is not smooth but i solved this problem by slowing the video down in Movie Maker , then in PI move it frame by frame , then in movie maker make it fast again. hope it helps..
Great Power Needs Great Responsibility..
