Simple question from Newbie
COW Forums : Particle Illusion
opusguy
on Jun 12, 2006 at 11:52:30 pm
Am using the SE version, and don't know how to " regulate " the length of time that an emitter " does it's thing ". In other words, I just want the thing to come on, do it's thing for say, 5 secs, and then " vanish " into a black screen.Hope someone can help me.
Thank you very much
Elvis Deane
Re: Simple question from Newbie
on Jun 13, 2006 at 3:06:01 am
There are a few ways to do this. First, you can animate the Number graph and set a keyframe with a value of 0 at the frame you want the particles to stop emitting. That will kill any new particles from being born.
You can also just fade the particles out by setting a key with a 0 value on the Visibility graph. Particles will still be created, but they'll be invisible.
If you just want to turn the emitter off entirely, you can set a key on the Active graph which acts like an On/Off switch. All the particles from that emitter will vanish at that point.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
opusguy
on Jun 13, 2006 at 4:05:53 am
Thanks Elvis-I will give it a go.
