Zzzzzzzzzzz
COW Forums : Particle Illusion
razors
Zzzzzzzzzzz
on Jun 9, 2006 at 5:44:08 am
Gotta comp some 'Zzzzzzzzzz' onto to a guy sleeping and as time is a factor (I don't have too much) wondered if anyone had already made one they'd be prepared to share? Or could think of a good emitter I could "tweak" easily and quickly.
Appreciate all help given fellow pIllionists!
Razors
Elvis Deane
Re: Zzzzzzzzzzz
on Jun 9, 2006 at 6:01:59 am
There are some hearts floating up in this library that would probably work pretty good. If you don't like the wobble, you can just crank down the Spin.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
The particleIllusion FAQ
Razors
Re: Zzzzzzzzzzz
on Jun 9, 2006 at 6:19:54 am
Many thanks Elvis! Cool Hearts as well, always useful. Now just gotta play with my Forces to get them to float slighty right.
Cheers again.
Razors
Elvis Deane
Re: Zzzzzzzzzzz
on Jun 9, 2006 at 8:25:20 am
You can reduce the Emission Range to 10 or 15, and then play with the Emission Angle so that they fly in the right direction. Sorry, should've mentioned that before.
Elvis Deane!
Razors
Re: Zzzzzzzzzzz
on Jun 13, 2006 at 12:05:36 am
Once again, thanks again for all your help Elvis. This is definately the best, most helpful forum I read!
Razor
